Re: Original Engine in a Super A or not?????
Posted by tempola on November 24, 2010 at 11:12:36 from (207.119.214.51):
In Reply to: Re: Original Engine in a Super A or not????? posted by AL Farmall Boy on November 23, 2010 at 20:59:50:
It looks like possible a later model engine, as you have traces of yellow paint.
it is most likely from a super A or C,or indrustal because the water pump is present.
it's not a powerunit engine, but that "indent" in the head below spark plugs 2 and three looks strange. the tube going into the rocker cover is another way to supply oil to the rockers. I suspect that head has been repaired and blocked off in the oiling area.
I don't think it's from a 140, because the 140 had a more conventional water pump(I think)
If you are not going to use the tach drive on the distributor, I'd like to buy it. I would supply you with a block off plate.
Andy
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
