Very close, except the one way clutch is not involved when the TA clutch is engaged.
Power is applied to the sun shaft. With the TA clutch released the carrier is held by the one way clutch and power is transmitted from the sun shaft, through the pinion gears, and out through the output shaft. Assuming a 2/3 gear ratio, does the one way clutch have to hold 1/3 or 2/3 of the torque?
The TA clutch only has to hold the sun shaft stationary with relation to the carrier. So does the clutch carry 1/3 or 2/3 of the load?
To add more complications, there are two different gear ratios on the planetary gears.
Whatever the real answer is, the torque that the TA clutch has to control is much less than engine torque.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
