Re: International 460 Fluids and steering
Posted by Fallon on December 01, 2010 at 22:32:39 from (75.106.194.183):
In Reply to: International 460 Fluids and steering posted by Fallon on December 01, 2010 at 17:29:00:
The tractor is definitely a 460 Utility.The frozen steering unit is directly under the dash . The steering wheel is attached to it. Distance between the steering wheel and this unit is only a matter of inches. The unit is cone shaped and only about 10 inches in length.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
