Re: To much free play in C clutch
Posted by justin on June 30, 2000 at 19:52:56 from (12.34.184.104):
In Reply to: To much free play in C clutch posted by Paul Shuler on June 30, 2000 at 19:33:37:
Well, here is what may be happening with your clutch.. Sounds like the release bearing may be the Carbon type bearing like is in the cub.. If so, the bearing is probably worn beyond use, and there may be a possibility that the clutch fingers are being worn away.. I would suggest that if this is so, you need to replace the pressure plate assy, driven disk, and release bearing.. The carbon type bearing for the C runs around $125, but you can buy a thrust ball bearing carrier from a salvage yard, and a new ball type throwout bearing for about 1/3 the cost of the carbon bearing..
Post A Followup
: Re: Re: To much free play in C clutch
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
