Re: Looked at tractor today...generator problems. Expensi...
Posted by farmallhal on December 05, 2010 at 19:29:43 from (76.2.182.168):
In Reply to: Re: Looked at tractor today...generator problems. Expensi... posted by RTR on December 05, 2010 at 19:20:51:
A 12 volt battery will be your biggest expense but there will be other things, like a different coil or ignition reisitor, something to excite it to charge, pulley change, mounting hardware, wire to intergrate into the existing tractor wiring, etc. It all adds up and then you have a tractor that doesn't have a known wiring diagram and can't be understood by anyone (like my BIL's M) as changes get incorporated into the system to "make the 12 volt work". Your tractor will work fine with a 6 volt system if you locate and fix the problem component or components, Hal.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
