Re: Cracked Block In Farmall B
Posted by Stuart on December 06, 2010 at 05:19:43 from (64.198.86.189):
In Reply to: Cracked Block In Farmall B posted by Farmall-H on December 05, 2010 at 13:30:38:
Actually you may be able to have that block furnace welded, which if they can do it, it will be as good as new. Try asking Midwest Cylinder Head in Nevada Iowa. A and B blocks are getting a little hard to find. I know they can weld a cylinder head up good as new. I have had several rare or hard to find heads welded up there with great results. Hope this helps
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
