Re: Looked at tractor today...generator problems. Expensi...
Posted by tempola on December 06, 2010 at 06:04:57 from (75.121.252.205):
In Reply to: Re: Looked at tractor today...generator problems. Expensi... posted by RTR on December 05, 2010 at 19:25:33:
the original starter will work fine as long as you do not crank a long time.
go to a battery place and ask if they have seconds or blemishes. usually 20 to 25 dollars.
Chevy alternator, order one for a 1973 Chevrolet pickup, with a 350 V8. you will have to fashion brackets, or get a ready made one from e-bay $50 max.
Coil resistor....about 10 to 15 dollars.
reverse the leads on your ammeter when changing to negative ground.
still cheaper than a replacement generator.
Andy
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
