to add to charlies post, you need to turn the drive coupling so one half of it points vertical. its basically a real thick flat washer with two raised areas, like a cross. also when in there replace the seal on the drive dog that comes out of the trans. check the trans input shaft seal too, if its leaking, change it now. when you separate the pump from the resevoir, you can slide a small bar to lock the pump gears to spin off the pump drive to change the seal. when putting the pump back on the resevoir, be sure to get the little fork hooked up to the bracket that actuates the pump from the control rod. if you get it hooked, the control rod wont work and you will need to drop the belly pump again.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
