Posted by Heath72 on December 19, 2010 at 16:58:17 from (208.126.22.30):
In Reply to: Re: 1951 Farmall H posted by bmagee on December 19, 2010 at 16:15:27:
The motor was good. I took the valve cover, side access covers and the oil pan off and replaced all the gaskets(and cleaned sludge out of the pan). The valves were checked and 4 of them reset a little. I suggested this to the owner, as the last thing you want is oil all over your fresh paint job!
The parts that were sandblasted were the chassis, hood and grille. The guy that does my blasting has done many tractors and knows where to be carefull. He does the sheet metal lightly, then I have to use the wire brush and/or the DA sander to smooth it down before priming. I also cover everthing I don't want sand to get into with three coats of duct tape, and then make sure it is good and tight. The neat little toolbox, headlights and pre-cleaner were beadblasted due to their thinness. Fenders and gas tank were power wire-brushed.
Believe it or not, the paint is just CIH 2150 red w/hardener. On the sheet metal I use about a dose and a half or so of the hardener and a SLOW-drying thinner. This gives a lasting gloss equal to a new car finish for a little over $100 a gallon. Beats $500 per gallon for red urethane!
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
