The secret is to limit primary ignition current to the range of 3.5 to a little over 4 Amps, (points CLOSED engine stopped, ignition switch "on") to prevent overworking the points so they quickly burn and/or overheating the coil.
The CORRECT combination of the original 6-Volt coil AND external ballast resistor with the proper value will achieve this and even allow for a "starting bypass circuit" to give full voltage to the coil for cranking, if desired.
OR, a "true" 12 Volt coil that needs NO ballast resistor will work, instead. (NAPA IC14SB, for example.)
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
