The roll on its side did do it. It took contaminated material that was held down by gravity and put it back into circulation. Either in the gears, or the hydraulic pump. When it is apart, make sure everything is flushed clean, and clean the screen in the reservoir as well. One chip of crud will take out gears when they have no place for the chip to go. In a pump the gears also jamb, causing stripped teeth, or sheared Keys. Good luck. Sand the inside of the Pulley when it is off just enough to allow a medium press fit for install. Do not heat it too much warmer than 200 degrees when reinstalling, or it will melt your new front seal. Jim
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
