All depends on HOW you want to wire it. I've got two that I rewired and stuck on alternators. I added a separate starter relay and and a separate glow-plug relay. That takes the load off the start button and glow-plug switch.
Specific alternator wiring depends on what alternator you want to use. If a Hitachi or Delco, also depends if the alternator has a self-excite regulator, or needs excite current from the ingnition switch.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
