Re: Ho of F-30 M
Posted by Tom Fleming on January 02, 2011 at 13:46:53 from (67.20.243.240):
In Reply to: Ho of F-30 M posted by Farmallb on January 01, 2011 at 09:57:27:
F-30 is 24.9 at the drawbar and 32.8 at the belt. 5,300 lbs. without added weight. bore and stroke 4.25x5.00 inches 283.7 CID 1200 RPMs
M is 33.1 at the drawbar and 36.6 at the belt 4,900 lbs. without added weight. bore and stroke 3.875x5.25 inches 247.7 CID 1450 RPMs
so 9 more HP at the drawbar, but 400 lbs lighter. The F-30 is probably geared lower. I would expect the torque on the F-30 to equal or better the M at the same RPM. The f-30 should lug better, but the M with 9 more HP should be able to pull an extra plow.
so, using the farmall Cub as the base (at 9 HP and a 1 12" plow tractor), the M should pull 1 more plow than the F-30. My conclusion, it is VERY close to a toss-up, but I give the M the edge. They are so close, not sure I want to put money either way.
all my comments are based upon each tractor being STOCK, and not modified. I am a big fan of torque, but you do need the ponies to get work done.
as always: IMHO.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
