Re: Timing a Cub
Posted by mkirsch on January 09, 2011 at 05:50:23 from (67.253.216.24):
In Reply to: Timing a Cub posted by Dave H (MI) on January 08, 2011 at 13:02:54:
You can also do it with the spark plug.
Find TDC on the compression stroke on #1 cylinder.
Put a plug in the #1 wire and ground it against the block.
Roll the distributor away from #1.
Turn on the ignition.
Roll the distributor until the spark plug fires.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
