Farmall B axle bearing removal
Posted by gregk on January 09, 2011 at 18:52:20 from (75.104.160.36):
I am trying to find some of the noise fro the rear end of my 46 B. I am in the process of taking off the left axle. I removed the wheel and the final drive pan, bull gear, axle shaft, and am going to remove the long axle shaft and housing from the trans so I can inspect seals and brakes. My question is on the short axle shaft that the wheel mounts to the outer bearing is pressed on? that is my guess and I would like to inspect or replace the seals but I cannot get to them until this bearing is removed. Any tips or words of warning? thanks
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
