Re: Service manual for a 1952 H - does it matter which one?
Posted by El Toro on January 30, 2011 at 07:36:19 from (108.3.200.96):
In Reply to: Service manual for a 1952 H - does it matter which one? posted by dstates on January 29, 2011 at 19:32:13:
third party image
third party image
I've had this I7T manual since 1975. Cost was $4.00 back then. I used it on the Farmall A. Hal
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
