Reattatching Woods L59A Mower Deck to 130
Posted by Dan 130 on July 12, 2000 at 15:30:55 from (24.4.252.144):
I knew I should have drawn a pix when I removed the woods deck so I could plow snow last winter. I can't get the belt cofiguration figured out so the blades turn the right dirction. I installed new blades the same as the old ones, but after installing the belt in what I thought was the right configuration, it rotates backwards( Wont cut grass worth a #$%$%# that way. This isn't the easiest deck I've ever mounted and I'm sure I am doing all the wrong things ( Mosquitoes have really enjoyed my efforts) Is there a page which shows proper belt installation avalible or any other suggestions ? How do you take tension off the belt to dress it ? Not much blood left for mosquitoes.
Post A Followup
: Re: Reattatching Woods L59A Mower Deck to 130
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
