Yes you can do a hydro yourself but first you need to do a little home work. Does the tractor slip under load or not move at all? By blowen do you mean there is metal in the oil. there are several checks that you need to do before a tear down. These trans are kinda fun to work on and very rebuildable in you own shop. I get my parts at a hyd shop, you can lap the rotating group at your shop, I have takes a lot of time. The only bad thing on the 656,666,hdro 70 is if the charge pump is bad then it hurts$$. Most important be clean. Any ??? drop me line. Good luck Bob
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
