Posted by Owen Aaland on February 11, 2011 at 16:06:42 from (63.167.132.13):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
If the crankshaft was reground you should not be using .001 bearings. Maybe you meant .010?
Oil pump problems on those engines is almost always blown out gaskets due to warpage on the bottom cover of the pump. Straighten it out, sand it smooth and make a small reinforcement bar to go across the area where it warps.
Priming the oil pump should never be a problem on those engines since the oil pump sits below the level of the oil. They will prime themselves within a couple of minutes of putting oil in the pan.
Since I don't think that you installed the wrong bearings the most likely cause is an oil galley plug left out after the engine was cleaned.
Early blocks did not use any camshaft bearings. The cam rides directly in the block bores. Later engines in that series used a bearing for only the front journal. They all use a bearing for the governor/distributor drive gear.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
