Posted by Janicholson on February 20, 2011 at 18:05:18 from (67.72.98.45):
In Reply to: Non running cub posted by Kyrock on February 19, 2011 at 19:11:47:
There is a possibility that the carb needs more cleaning. (or) Was fuel able to be drained out of the carb at a rate approaching 3/16" stream? if not it is still plugged up somewhere in the delivery system. There is a screen at the carb inlet that is often overlooked. Is the intake manifold leaking air at the engine flange or the carb flange, either will be a vacuum leak and cause lean running. Good luck, and keep us in the loop. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
