Tug, The 3/8 hole in block should be a breather tube for block. You may have a blockage on lower elbow or in block. I would pull lower hose and make sure it is cleaned out. use a coat hanger to pull out debris. Also could put water in top elbow and flush it out. The rad will get hot. oldiron29
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
