Re: 1955 farmall 400 compression ect. ?
Posted by Janicholson on February 27, 2011 at 17:14:53 from (67.72.98.45):
In Reply to: Re: 1955 farmall 400 compression ect. ? posted by Bugspotbb on February 26, 2011 at 16:19:18:
Loose clearance on the distributor bushing can and will cause erratic timing as well. Setting it to TDC with engine off and marks lined up should get you to the correct advance when at high idle (wide open). Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
