My engine book does not give a block bore size for the light press fit block, serial number 71777 and below. For the heavy press fit sleeves, block serial number 71778 and above, the bore size for standard sleeves is 3.8123 - 3.8137. For .002 sleeves the bore size is 3.8143 - 3.8157. For .010 oversize sleeves the bore size is 3.8223 - 3.8237.
Light press fit sleeves need 25 to 75 lbs pressure to install, closer to the 75 is better. Pressures above 75 lbs is allowable for the last inch. Sleeve height above block is obtained by using shims. Height should be .001 - .004 with sleeve clamped down. Try to get no more than .002 between two adjacent sleeves.
Proper fit for heavy press fit sleeves is obtained by requiring no less than 750 lbs for at least five inches of travel. Pressures in excess of 2500 will require honing of the block to get proper fit. Sleeve height above block is .035 - .045. The sleeve installation tool will install the sleeve to the proper height.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
