Posted by Janicholson on March 03, 2011 at 18:57:21 from (67.72.98.45):
In Reply to: Lighter front on m posted by Pigpen on March 03, 2011 at 18:00:23:
there is probably an alloy that could work, but the shaft is not that heavy, and its integrity is a safety related concern. Removing weight from the cast iron of the bolster is more likely to be shedding pounds. removal of the crank start shafts, a wooden dowel would look original, and break off if you passed by to close (rather than taking out a kidney as it does now). running on a small motor cycle battery and starting it from a jump. eliminates the generator regulator and assorted brackets. Jim
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
