All wiring is fine to use as is. The insulation should be checked to assure it is not cracked or worn through at any point, but the 12volts will put less amps through the wires, making it easier on them. As it is a mag, there is no issue other than lights. Do it your way. Sense it probably had a 4 position light switch, make sure that the new wiring of a voltage regulator does not use that part of the light switch formerly used for the generator charge rate control. It is a direct ground or ground through a resistor that is connected to the field terminal of the gen in its former setup. The field terminal now connects only to the Field terminal of the new regulator. Jim
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
