Re: Farmall B Cultivator- Urgent
Posted by old on March 14, 2011 at 14:44:32 from (4.245.12.240):
In Reply to: Re: Farmall B Cultivator- Urgent posted by corbincdc on March 14, 2011 at 14:00:48:
The spindle tubes in your picture sit so that the tire is back instead of forward like it should be. Those spindle tubes which is the part of the front axle that has to parts that move to turn the front wheel should sit at a bit of a forward angle or straight up and down instead if sitting so the front wheels are back like they are in your picture
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
