Re: Chipped Bull Gear
Posted by Mike Bock on March 14, 2011 at 18:33:41 from (70.200.239.92):
In Reply to: Chipped Bull Gear posted by IHRedRules on March 14, 2011 at 16:52:50:
get you a new gear , i wouldnt replace the pinion gear, these are slow speed gears and will out last you and me if bearings are kept tight i have welded on gear teeth before with a mig and filed them down to match ,just chipped teeth though on my pulling tractor ,new gear is very hard to find AC rc gears and that was 6 years ago and had 3 times horse power run through it and still holding up M gears are easy to find and as hard as it is to change should be replaced just for peice of mind
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
