An electronic ignition (eliminates and replaces points and condensor) is NOT any magic elixir or cure all for many ignition problems such as the distributor cap or rotor or bad plug wires or bad plugs or worn distributor bushings etc which may be even worse with an elec ignition if you run at higher voltages.........If the distributor has good bushings and you install a new set of points and condensor and have a good cap (no hairline cracks or carbon traces) and good plug wires n plugs plus a good coil you may be fine. However most people report improved starts and idle with an elec ignition BUT YOU STILL NEED A GOOD CAP AND ROTOR AND GOOD WIRES AND PLUGS.
If you are going to convert to elec ignition Id go with negative ground and if you swap to an alternator most also require Neg ground. . If you change grounds the ammeter leads need swapped and the coil is also polarity sensitive regardless if you use elec or points ignition.
If you do convert to elec ignition Id match up a high energy (12 volt if youre going to 12 volts DUH) coil with it to get the most bang for the buck the elec switch has to offer and use good quality plug wires.
A good H should start n run fine with an original 6 volt system at Pos ground if originality is any concern for you
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
