There are four considerations for your answer. The rear of the TA has a sprague clutch (ramp rollers) easy to replace with the tools you indicate. The clutch on the front is a standard friction disk and pressure plate with a throwout bearing. No issue, easy. The internal parts should be checked for gear tooth wear and bearing support wear. If you know what tooth and bearing wear looks like no issue. The last is adjustment and re-manufacturing of pins and clevises in the linkage. The tractor must be split in two places to get it out. it is heavy and safety is important. Kevin Meier on this forum sells parts and complete TAs. Jim
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U
... [Read Article]
