Re: Gear Mesh between bevel pinion and ring gear
Posted by CenTex Farmall on March 16, 2011 at 21:56:46 from (32.176.26.247):
In Reply to: Gear Mesh between bevel pinion and ring gear posted by Tom in Iowa City on March 16, 2011 at 17:03:57:
I would sacrifice the gear backlash spec in favor of matching the existing wear pattern. Some extra backlash won't hurt like it would in a highway vehicle where you have a lot of accelerate-coast-de-celerate cycles that can rapidly load and unload both sides of the gear teeth.
If I had NOS parts I would definately follow the book and set things up accordingly. With these 80 year old parts the original tooth profile had changed due to wear. I can see in the photo where the old pattern is. The gears will be a lot happier (and quieter) going back to their old set way.
I'm with Jim on moving the pinion in to at least better center the pattern that you have.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
