Re: Farmall B Cultivator- Urgent
Posted by gene bender on March 17, 2011 at 12:16:09 from (67.55.227.7):
In Reply to: Re: Farmall B Cultivator- Urgent posted by Chris Corbin on March 15, 2011 at 18:15:41:
I dont see how you are going to make the cult from the B fit that tractor as the wide front and steerin rods are in the way. You mite be able to make a new plate bolted to the front that would set the frame for the B stuff back some as they have covered up the mounting holes for the wide front assy. See you can remove the wide front and get the narrow pedestal for a B then the cult will fit. There is neough room on the shanks and the pressure rods to make it lift and lower. The original front steering sector is still on the tractor and by removing the wide front and putting the oroginal pedestal back you are in business.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
