Re: 560 Dies
Posted by El Toro on April 03, 2011 at 04:08:10 from (108.3.156.106):
In Reply to: 560 Dies posted by redtailwis on April 02, 2011 at 19:53:01:
Disconnect the gas line at the carburetor and see if you have a full stream of gas from the tank. Use a clean container to catch the gas.
If there's just a trickle of gas you need to clean the gas tank. If you have a full stream of gas remove the gas fitting where your gas line connects and look for a screen behind that fitting. It be could full of dirt or rust. If
the screen is clear of any dirt your carburetor probably needs a good soaking in carb cleaner and a good cleaning. Blow out all the jets with compressed air. If that carb has a solenoid at the carb inlet it may not be opening fully. Hal
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
