Re: Farmall h starting problem again
Posted by Janicholson on April 03, 2011 at 12:12:01 from (67.72.98.46):
In Reply to: Farmall h starting problem again posted by Farmallboy15 on April 03, 2011 at 06:23:10:
The points and condenser are connected to the stud (pass through) on the side of the distributor. This connection is often incorrectly reassembled causing a short to ground that would also make the coil warm up due to being on all the time.
The order of stuff from outside to inside is:
nut, lock washer, flat washer, connector from coil loop, lock washer, nut, flat washer, plastic/fiber insulator (with small end in the hole), then on the inside, a flat fiber washer (insulator on the inside over the small end from outside), flat washer, nut, spring and copper (on some), condenser connector, lock washer, nut.
This makes it conduct directly to the points movable contact.
Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
