Re: '46 H Stuck in Gear
Posted by S-E Michigan Part Timer on July 24, 2000 at 20:26:26 from (208.223.205.166):
In Reply to: '46 H Stuck in Gear posted by Bill White on July 24, 2000 at 19:00:08:
I've heard of this before, and did do it once to an M. I guess some can actually get stuck in two gears at once. Now that you've tried to move it, two different gear sets w/ different ratio's are fighting against each other, causing a pretty good bind you notice in the shifter. Supposedly, if you rock the tractor back and forth by the rear wheel, you can get it back into neutral. Not sure how hard you'll have to rock this one, may need two of you.
Post A Followup
: Re: Re: '46 H Stuck in Gear
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
