Re: supe c sticking in two gears
Posted by Janicholson on April 07, 2011 at 19:19:26 from (64.61.211.178):
In Reply to: supe c sticking in two gears posted by DENNIS REID on April 07, 2011 at 16:19:26:
With the lever out, use a small clean stick to fit into the rails. (in neutral) whittle it down till it fits well front to back, and side to side in one rail notch. round the bottom corners and top recess so it can move the rails forward and back. Make your shifter the same, Try it and grind or file off just enough to make it work freely but snugly. Jim.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
