Posted by rustyfarmall on April 15, 2011 at 12:54:20 from (209.152.78.140):
In Reply to: Model 340 Tachometer posted by LRRifleman on April 15, 2011 at 12:40:54:
The tachometer needle should be every bit as steady as the speedometer in your car. Did the shop repair the tach? Or did they just replace the tach cable? If they replaced the cable, did they get it installed correctly?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
