Dead F20
Posted by Bruce Simmons on July 28, 2000 at 03:58:11 from (216.179.5.98):
My F20 had been running OK, but had become
harder and harder to start. Finally died. Will not even pop.
Checked spark, found it weak. Replaced points,
condenser, coil, plugs. Checked carb and re
adjusted. Adjusted valve lash .018. Checked
fuel flow. Good flow to carb, but no gas
getting to cylinders. Discovered that there is
no vaccuum. There's a leak somewhere, right?
But I can't find it. This tractor was running
fine, so whatever happened, happened quick.
As a non-mechanic, I've about run out of ideas.
Can anyone out there help? By the way, did compression check. #1 72 lb., #2, 70 lb., #3 66 lb
#4, 72. Is this high enough? Seems pretty even.
Post A Followup
: Re: Dead F20
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
