Re: engine oil for cub
Posted by Denny ('60 Lo-Boy) on April 17, 2011 at 05:56:29 from (71.50.222.251):
In Reply to: engine oil for cub posted by CharlieNJ on April 17, 2011 at 04:44:11:
Use what ever your oil of choice is for any other equipment you have. Today's oils are far superior to what was available then. I use 10w30 or 30w.
For the hydraulic system, Case/IH Hy-Tran is the preferred choice but I use Tractor Supply Universal hydraulic fluid. Does a good job.
In the transmission use 90w gear oil. It only takes 3 1/2 PINTS. If overfilled it will just leak out the seals and coat the brakes.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
