Removing Injection Pump from 1256
Posted by JWCarp on April 23, 2011 at 04:44:11 from (67.142.163.28):
I just bought a 1256 that needs some work done on the injection pump. Reading the IT manual I have it says to take off the turbo and the exhaust manifold and then remove the pump with the lines on it. Does anyone have any shortcuts to removing the pump without taking the manifold off? Can I pull the manifold and the turbo together or do you have to take the turbo off the manifold like the manual says? Thanks for the help.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
