No. That is blow by and a ring issue usually. Try putting a teaspoon full of ATF in each spark plug hole, crank it to distribute the ATF, then put the plugs in and let it set for three days or so to loosen the rings. If it has just gotten worse over the years, it needs rebuilt. If the ATF does no good (it will smoke when first started) rebuild is in order. Check the oil pump when it is torn down, it can cause low pressure. Jim
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
