First tractor I bought when I took over the farm in 1971 was a '67 806D. I pulled a 14" #560 plow, 13 shank #55 3pt chiesel, 18 1/2" #480 disc. w 3 bar spike harrow 18 1/2' #45 field cultivator w/3 bar spike harrow, and a 13' #370 disc with a 15' Brillion cultimulcher hooked behind the disc. The chiesel was a little too big but the tractor handled everything else OK in our black loam soils. Tractor did have duals & fluid in the inner tires (18.4x 34s)
Hard to believe the first 06s are approaching 50 yrs old. Doesn't seem that long ago that they came out. I'd be a little hesitant about overloading a 45+ yr old tractor.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
