Posted by D Slater on May 09, 2011 at 19:59:57 from (184.15.26.40):
In Reply to: 1952 Super M Head # posted by BUCK CLAYTON on May 09, 2011 at 16:04:07:
Randy answered the head question. 356994R92 is the part # for a replacement head assembly with valves, springs,spring retainers and rotocaps. That head casting is 8574DC. 356981R93 is a replacement block assembly. Casting # on that block is 365586R1. 356980R1 engine blocks came in SM, SMTA, part of the 400 tractors and W series in the same time frames. To see if that block is probably original to the SM. Check the date code on the block or see if that engine serial # was installed in a tractor the same month tractor was built.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
