The no shutdown problem is a bad kill switch ("ignition" switch). Either the switch itself is bad, or the box it's mounted in is not grounded to the tractor frame. (Keep in mind the kill switch works by grounding the magneto primary when turned off so the mag won't send fire to the plugs.)
The dead battery can have several causes:
1 - Battery is worn out and will longer hold a charge.
2 - Charging system has problems and is not charging the battery when the engine is running.
3 - The cutout (or the cutout relay inside voltage regulator if so equipped) has stuck in the closed position causing the battery to discharge when the engine is stopped.
To figure out which it is, watch the ammeter:
If it shows charge when running and 0 when stopped, you need a new battery.
If it shows 0 at all times (running and stopped) either the generator or cutout has failed.
If it shows charge when running but then discharge when shut down, problem's a stuck cutout/voltage regulator relay.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
