Chad, good for you! Best thing you can do is to check the valve lash. correctly adjusted valves should not have that happen. It could be related to the valves hanging up, but I would definately check the lash. Also, if the valves were stuck, you could have bent push rods, which can cause that to happen.
This post was edited by Tom Fleming at 18:50:47 07/10/11.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
