Posted by ohio03trdtaco on July 13, 2011 at 09:58:24 from (208.66.214.251):
Well I took the pump off for a rebuild. I found the gear was wobbling on the shaft a little bit. The washer was bent up to hold the nut from backing off and the key was in place. The nut was only finger tight though. So I figured some one hadn"t put it back together right and bought a used pump. Now the other pump is slightly different style. Will bolt up and work fine.However the drive gear is in exactly the same shape. It is a little loose and wobbling on the shaft. So is it normal for that gear to wobble a little? If it is I will probably just use the original pump, do to wear patterns on the gears. I haven"t tried IH yet but can I source a new gear?
Today's Featured Article - Talk of the Town: Diesel Vs. Gasoline - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I am in the market for an older tractor (to be read... cheap). I have been told a diesel holds up better than a gasoline engine as far a wear, tear, neglect and abuse. Since I am looking at older tractors that have probably been through it all, is it better to buy diesel? I do expect to have to do a good bit of work on
... [Read Article]
Latest Ad:
[More Ads]
