Posted by D Slater on July 19, 2011 at 18:28:27 from (184.15.41.100):
In Reply to: 400 diesel part 2 posted by Workman on July 19, 2011 at 12:31:42:
Can't remember exactly how all the parts are placed, but B primary pump has the bypass valve that I think you mention. Small hole is a passage to the suction side of the primary pump. Any fuel that leaks past the distibutor valves is supposed to be sucked in. If a original gasket is between injection and primary pump it has a small hole for the passage both ways its installed. If someone made a gasket the holes may not be open to each other. Sump oil can get to the primary pump drive end.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
