Re: Farmall M Gears in front not turning
Posted by Bill in NJ on August 20, 2011 at 09:08:38 from (4.248.92.7):
In Reply to: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 08:55:32:
If the engine front pulley is turning when you hit the starter, the crank is not broken. However the crank or cam gear could be broken, or stripped. Pull the timing cover off of the front of the engine and you should see the problem.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
