BC144 governor
Posted by Fritz Maurer on August 20, 2011 at 10:20:49 from (216.137.136.148):
I've got this engine in a 434 tractor. Governor response is terrible. I opened the throttle wide and moved the governor lever in the same direction, and set the link for this distance. Is this procedure correct? Joints are not stiff,and linkage not rubbing on anything. Any ideas? Thanks, Fritz
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
