Posted by El Toro on August 21, 2011 at 12:20:48 from (108.15.86.54):
In Reply to: H starting problem posted by Wyokid on August 20, 2011 at 15:22:20:
When it quits running pull off a plug wire and see if there's fire to the plug. You need to do this asap when it quits. If there's no fire, I would first replace the condenser and see if the engine will stay running. If there's still no fire you probably need a new coil in the mag. Hal
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
