Re: H steering shaft
Posted by Bob M on August 22, 2011 at 16:14:32 from (69.207.87.100):
In Reply to: H steering shaft posted by metalmender on August 22, 2011 at 15:08:25:
Yup - there's a bushing at the bottom of the worm gear box. New bushings are readily available from CIH and elsewhere.
Replacement is relatively straightforward. You need to remove the lower bolster (the casting that holds the front wheels) then drop the bolster pivot shaft. The bushing and the seal beneath the bushing can be driven out and new parts installed.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
